How do I select a set of points along an edge and make it a point group.
Also how do I use poly loft to bridge 2 point groups(with ref to prev. post)
Cheers
Lanchka
point groups
2916 1 1- lanchka
- 18 posts
- keltuzar
- 18 posts
The reason I didnt want to answer the question in your “bridging” thread becuase it is pretty simple, and if u take the time to read the help page of the group you would have figured it out.
Not for the answer there are 2 ways…
1) press “s” select the 2 points and press “tab” and type in group and your 2 points will be in the group sop.
2) append a group sop, turn on point numbers and select Number and in the pattern field type in the number of the points eg:- 130 1020 depending on the point number of the point you want to be grouped.
