Hi, I'm interested how geforce 6800 works with houdini (I have problems with Ti 4600 and radeon 9700)?
Would it be better to buy 6800 or quadro fx 1400 (which is slower in normal conditions)
I noticed some strange behaviour: on radeon I'm unable to work, and ti 4600 frequently and slowly refreshes icons.
Peter
Geforce 6800 with houdini.
5995 5 3- peliosis
- 175 posts
- MatrixNAN
- 405 posts
- stevenong
- 1634 posts
Hi Peter,
Are you using the latest Nvidia drivers? If you're not, please download it from Nvidia's site to see if it helps.
If you are using the latest Nvidia drivers, there is an environment variable you can set which should fix the redraw issues.
HOUDINI_OGL_DBL_BUFFER_FIX
Set the variable & the value of the variable is 1, which will turn it on, so to speak.
Hope the above helps!
Cheers!
steven
Cheers!
steven
- peliosis
- 175 posts
- craiglhoffman
- 252 posts
Using 6800 fine with Houdini.
Remember, the 6800 is the only card with Pixel Shader 3.0 available right now. My guess is that if Houdini ever supports real time rendering with VOPs, etc. it will be with Pixel Shader 3.0 capable cards due to the streamless branching and much larger shaders, etc. so buying a card without this technology may not be a good investment.
-Craig
-Craig
- aracid
- 154 posts
hey all
im using an average nvidia 5700 ultra
and i get quiet good results, however ive also run a tool called
RivaTuner - a complete powerful tweaking environment
and that over clocks my card to act like a quadro 1100,
and it does seem faster in houdini :-)
now i know there are major performance differences to the actual quadro range, however whats ur take about this ?
aracid
aracid
