v14 release – Render to Mantra doesn't work
8071 10 2- cgbeige
- 99 posts
- anon_user_37409885
- 4189 posts
- cgbeige
- 99 posts
- 4189 posts
hmmm - sounds like something is up then. The ‘Houdini Terminal.app’ should work by typing ‘Houdini’, and when using pwd it should be your home directory.
Is there any error, red stripes, on the mantra node when you render? Try MMB on the node if there is to see the error- usually its a missing camera.
- jordibares
- 655 posts
- vipvip242
- 3 posts
i've just bought an Houdini indie licence, which is working but when i want to render with mantra (whatever the resolution), it doesn't work and a message appears telling the mantra license is missing/not active.
For info, i've received one indie licence but no mantra one with it… perhaps i missed something ?
ps: working with the current Houdini 14 indie version, on windows 8.1 64
- SreckoM
- 379 posts
- vipvip242
- 3 posts
- neil_math_comp
- 1743 posts
@vipvip242: It sounds like you have to open up the Houdini License Administrator program, also known as hkey, and install your licenses, unless you've already done that. That's the first thing support will ask you about.
- SreckoM
- 379 posts
- vipvip242
- 3 posts
Hi, thanks for your support.
Sidefx just sent to me an archive with the missing renderer licence (perhaps because of a wrong operation on my part ).
Not installed yet because out of time but i'm sure it will work…
Anyway thanks for your help !
**edit**:
a message to ‘INDIE’ new users on windows: beware because when installing Houdini, the installer drop the ‘FX’ icon version on desktop, and not the ‘INDIE’ one: you have to launch Houdini with this one, otherwise it won't work (which is logic because this icon needs a ‘FX’ licence to work ) !
**edit**:
