Hi.
I'm making a burning cloth effect. I have a mesh and an attribute spreading over the surface to delete polygons.
When I try to simulate the deforming mesh it uses the first frame to simulate the cloth. I want the cloth object to update every frame to make the tearing cloth fall down as it burns.
I attach a snapshot to help you better see what I mean.
I've read that the cloth solver allows deforming meshes but I didn't find much information about that topic.
Any thoughts?
Cloth with changing topology
4484 4 1-
- Rush Visual Effects
- 10 posts
- michiel
- 435 posts
Hi
I've attached an example that uses a “burn” point attribute from the SOP level.
The setup uses a SOP solver to disintegrate cloth points that are burned.
You should be able to re-use this for your purposes.
You can animate the “burn” point attribute, setting it to 1 when you want a point to disappear.
Michiel
Michiel
- 10 posts
- 10 posts
Hello again, I'm applying the setup Michiel provided, it works fine but im having trouble with my constraints. I used a pt group called attach and then refer to it in a pin constraint. The guides appear but when I hit play and the topology starts to change the pins disappear. I tried with a target constraint and refering to the point numbers directly and happens the same. I also tried making the group in the sop solver but the problem persists.
I'm a bit lost, any thoughts?
Toledor
Toledor
- 10 posts
