Hi All,
I would like to resample a curve so that it has more divisions with sharp angles and less till virtually zero devisions when it is straight.
I want to use this for the sweep function.
Cheers
how to resample a curve depending on the curvature?
20939 6 5- kgoossens
- 289 posts
- Simon
- 2199 posts
- kgoossens
- 289 posts
- old_school
- 2540 posts
Remove in-line doesn't selectively remove points from curved areas, only the straight sections wich is fine most of the time.
Use Resample SOP as above then take away points using the Refine SOP.
Set First U to 0.
Set Second U to 1.
Check the Unrefine option.
Slide the Tolerance U back and forth to remove points based on curvature.
Set First U to 0.
Set Second U to 1.
- PhilipPappas
- 10 posts
i was trying to do the same thing, problem with this last method is that there is no local control. The curve gets refined the same way across the whole curve no matter the rate of change in direction. same thing with the facet sop. i think a more complicated approach is needed to make this more precise. maybe features should be grouped at first and then refined?
- tamte
- 8854 posts
- PaQ WaK
- 100 posts
Divide (avoid small angle ?) / polyreduce (equalize Lengths: 0 ?) / Divide (remove shared edges).
Not sure if the optional brackets(?) are needed.
For the same amount the final points, polyreduce gives a much better silhouette, … refine and facet tends to create very long segments with kinky curvature.
Gameloft
