defgeo
   3355   1   0
Hi! When I create a new geometry I dont see the dumy box, as it should be, but it appears a container with some volume in it. How can I fix this to get the default dumy box back???
If you accidentally switched your default file sop to write, and did not changed your filename, you have overwritten your defgeo, only reinstalling can help you or copy this in $HFS/houdini/geo
defgeo.zip (1.6 KB)
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
