having a problem.
I set the MSVCDir env var:
set MSVCDir=“C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC”
and I get the following error:
Failed to run C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\amd64\cl with error 2: The system cannot find the file specified.
the directory “…\VC\bin\amd64” does not exist. Instead, I have “…\VC\bin\x86_amd64”
this is likely the problem. What might be the solution?
H14 compiling, x86_amd64 error
3818 3 2- ivan
- 83 posts
- edward
- 7868 posts
“x86_amd64” is the 32-bit cross-compiler that creates 64-bit executables using a 32-bit compiler process. I'm guessing that you're missing the actual 64-bit, 64-bit compiler because you're running the Express version of Visual Studio. Someone claimed to have previously made it work using the HDK:
http://forums.odforce.net/topic/20731-path-deform-hdk-plugin/?p=124370 [forums.odforce.net]
Edited by - Feb. 11, 2015 22:44:43
- ivan
- 83 posts
- ben-andersen
- 47 posts
I got this to work by copying
CProgram Files (x86)/Microsoft Visual Studio 11.0/VC/bin/x86_amd64
to
CProgram Files (x86)/Microsoft Visual Studio 11.0/VC/bin/amd64
Then in hcmd, running:
“C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\vcvarsall.bat” x86_amd64
then hcustom worked for me using the cross compiler on 64-bit windows.
It's a shame that the only freely available compiler for vc11 doesn't ship with a 64 bit compiler.
to
