Attribute Vop in houdini 14
   5634   4   2
In Houdini 14 Vop Sop is hidden and we have to use Attribute Vop instead of Vop sop. But in attribute Vop, add attribute node has completely different menu compare to Vop sop. So can anyone explain me which one is replacement of “adata” in Houdini 14.
Manish Sharma
FX TD
You have to combine it with setattribute vop or just use bind export.
If you already have attribute on geometry then setattrib vop will work otherwise to add new attribute use addattrib or bind vops.
adata was the value of that attribute in addattribe vop in VOPSOP. Equivalent to this in attribvop's addattribe is value.
BTW VOPSOP was run in VEX context while attribvop runs in CVEX context where you can create geometry and it's faster too.
attributeVopPushimgVariable out.JPG (67.4 KB)
