Hi there, I'm wondering if there is a way to specifiy specific point number values.
Ie. Say I have 4 pts, normally houdini would tell me they are 0, 1, 2, 3 … is there a way for me to.. make point #2… have a point ID of 20.. so its .. 0, 1, 20, 3 ?
Specifically what I want to do is associate a PT# with a group.. groupA is always PT# 37, groupB is always PT# 22.
Thanks for your help.
Giving Pt's an specific point#
2759 6 2- Kfinla
- 100 posts
- animatrix_
- 4729 posts
Point numbers can not have gaps. You can easily do this by using another point attribute such as ptnum. Then use this attribute in your groups.
- Kfinla
- 100 posts
Thanks, I wondered about the gaps.
Could you be a bit more detailed about your ptnum explanation.
Right now my groups are based on pt0, or $N etc.. are you saying an attribute and then use the expression function in the group node to call it.?
Thanks Ken.
PS. I think I have every single animatrix OTL installed
Thanks Ken.
- animatrix_
- 4729 posts
I made a simple file showing it. So you can just use the local variable in the Group SOP instead of point expression. But defining specific values by hand for each point becomes tedious in any method AFAIK.
If it's a huge list, AttribWrangle in Detail mode would help where you could set point attributes using setpointattrib function per point.
As for Animatrix, thanks for your support, appreciate it
- Kfinla
- 100 posts
- PradeepBarua
- 443 posts
- PradeepBarua
- 443 posts
