anyone know a bit of quick python I can use to query the current Tab context folders available when I hit tab in a particular network view context.
i.e in SOP's it would return : “attribute”, “character”,“crowds”, “polygon”,“primitive”…
I can query the submenu path of each all available operators individually to build a list but that would be crazy
Query tab menu context folders
2916 3 2- _milo_
- 763 posts
- redpaw
- 75 posts
- mikelyndon-sesi
- 394 posts
You can access it through the HDADefinition class.
So if you have a node selected you could do something like,
import xml.etree.ElementTree as ET node = hou.node('/currently/selected/node/path') definition = node.type().definition() toolssection = definitions.sections()['Tools.shelf'] root = ET.fromstring(toolssection.contents()) for path in root.iter('toolSubmenu'): print(path.text)
- hernanllano
- 8 posts
mikelyndon-sesi
So if you have a node selected you could do something like,import xml.etree.ElementTree as ET node = hou.node('/currently/selected/node/path') definition = node.type().definition() toolssection = definitions.sections()['Tools.shelf'] root = ET.fromstring(toolssection.contents()) for path in root.iter('toolSubmenu'): print(path.text)
HI Mike, I was wondering if there is any way to set that same value, say for example that I want to set the TAB Submenu Path where the digital asset is stored when I press tab via Python.
