How can I restart a pyro sim from where it was stopped? I have .sim files, and I've read it's possible, but how? I'm using a dynamics node in the out context to start the simulation. I'm reading it in using the checkbox at the top of the pyro_sim node in the object level.
If you wanna continue your simulation from last simulated frame , you can use Explicit Cache , Just Save your simulation with this option to the *.sim files , then you can continue your simulation from last simulated frame later (Just Press Play Button ! ) :wink:
