Q: - General Python help !
   4068   11   1
Can anyone show me an example of how I can join nodes together for example a set of sop nodes in a for loop ie box > facet > null . I just dont quite get the syntax of how to have a list of nodes and wire one nodes output to another nodes input .
Kind regards
Rob
Edited by - March 21, 2015 22:38:06
Gone fishing
hey monkey i am not in houdini right now, you can do hou.node(nodethat will be below)setInput(0, thenodeyouwant)
Hi, I am specifically after being able to loop through a collection of nodes to connect them.
Gone fishing
sel= hou.selectedNodes()
for n,i in enumerate(sel) :
if n>0 :
i.setInput(0, sel, 0)
That's assuming output and input connectors are all index 0
Havent test it in Houdini as I replied from phone. But you got the idea.
Hi Ferry that works ! , it certainly helps me get to grips with python. My next issue to pull apart is defining functions. ! . I figured I should create the nodes , then list them , then join.
Rob
Edited by - March 21, 2015 22:48:03
Gone fishing
Just typo.
childrenOfnode(node) != childrenOfNode(n)
Thanks I go that ! ……. I think I must just turn this into a python thread. Thanks for all the help
Rob
Gone fishing
Hi all,
I can create a list of nodes children() how can I delete a specific node from a list . for example I want to delete the file1 node but there may be 25 nodes in there. I was thinking along the lines of a if statement to look at a list ie
variable = somenode.something(“file1”)
if var = true
blah.destroy()
master = hou.node('/obj')
node = master.createNode('geo', ‘obj_box’)
node.moveToGoodPosition()
for child in node.children():
print child
Rob
Gone fishing
# select OBJ node
sel = hou.selectedNodes()
# get children as list instead of standard tuple
childs = list(sel.children())
# remove from list and destroy node by using list comprehension as a filter
Thanks for the pointer I will give it a crack
Rob
Gone fishing
python ……..
# create empty geo node
obj = hou.node(“/obj”)
n = obj.createNode(“geo”, “box_obj”)
n.moveToGoodPosition()
p = n.parmTuple(“t”).set((2,0.5,0))
### create box node inside
b = n.createNode(“box”)
b.parmTuple('size').set((1, 1, 1))
sel = n.setSelected(True)
Taking the previous post I figured how I could automatically select an object on creation then delete the file1 sop. I am going to stick my neck out and assume its not best practice to select then delete. I had a crack at deleting the file1 sop with an approach where I did not select the node. All I got was hou.object didn't support inline . Any other workflows I could explore ?
Rob
Gone fishing
A little late, so you probably figured this out till now, but take a look at what arguments can be passed into this method:
http://www.sidefx.com/docs/houdini14.0/hom/hou/Node#createNode [sidefx.com]
If you set run_init_scripts = False, than it will create only container without file1.
