Randomly picking from set value list
   9317   8   2
How does one create an expression where the value would be randomly picked from a list of 9 pre-determined values.
Thank You!
Winter is coming!
Depending on your seed you can do this using Python:
import random
random.seed(lvar('PT'))
return random.choice()
What about using hscript or VEX rand() in conjunction with fit01().
i.e:
hscript
fit01(rand($PT), 0, 9)
or
VEX
fit01(rand(@ptnum), 0, 9)
PradeepBarua
i.e:
hscript
or
VEX
The values would not be 0-9. There would be 9 float values, each different.
Winter is coming!
pusat
import random
Excellent - Thank you!
Winter is coming!
firefly9000
pusat
import random
How did you make sense of that? …would anyone please care to elaborate? I'm after the same thing here. Even simpler, trying to randomly pick among a short list of values (0, 90, 180, 270, 360) to create orientation randomness on some objects scattered using a copy node, but restricting them to those orientations only.
A.
Adriano
firefly9000
pusat
import random
A.
I can't help you on the python part as I'm pretty rusty with python, but doing what you want in vex is fairly simple.
// create random integer from 0-3 generated from the point number, then multiply that by 90
float randVal = rand(@ptnum);
int degreeRotation = int(fit(randVal ,0,1,0,4)) * 90;
// @rot is a quaternion value a copy node will inherently read, you can also use other attributes like transform/orient/up etc…
float angle = radians(degreeRotation);
vector axis = {0,1,0};
@rot = quaternion(angle, axis);
hope that helps
Edited by electricalpencil - Feb. 15, 2018 15:37:19
Thanks man, I wish it did help, but frankly it didn't. Just simple stuff like “int(fit(randVal ,0,1,0,4))” which i assume should return a value between 0 and 1 and be remapped between 0 and 4 and turn it into an integer…. just does not work for me in any context. Houdini gives me an error “unable to evaluate expression, bla di bla…”. So that's not a good start, is it.
A.
Edited by Adriano - March 1, 2018 13:14:21
In vex it would be (int)float(floor(val*5))to get a value between 0 and 4 (assuming val already contained a random float between 0 and 1 from the rand() function.) You don't want to use fit/round because it won't be evenly distributed.
The hscript expression would be floor(rand(seed)*5), with seed being whatever you are keying the random with, e.g. ($PT, $F, etc)
Edited by jsmack - March 1, 2018 13:57:35
