Hi Guys,
I've searched but had no luck trying to figure out the Background Render option on the ROP output driver / DOP I/O node. I just can't get it to process anything. If I render the same thing with the regular render button it pumps out a sequence of Bgeo files - no problem.
Is there any trick to get this bad boy working?
Seems like it would be awesome to have this caching while I continue to work in Houdini.
Any help would be much appreciated
Background Render (ROP Output Driver etc.)
8354 8 1- Ben Watts
- 32 posts
- circusmonkey
- 2624 posts
- Ben Watts
- 32 posts
- circusmonkey
- 2624 posts
- Ben Watts
- 32 posts
- wlvl
- 23 posts
- Luke Letellier
- 241 posts
I'm having this issue as well. Houdini Indie 15.0.416 on Windows 10.
After clicking “Save to Disk in Background”, the job will appear in the list, and register as completed, but no cache files will be created or saved.
EDIT: Submitted an RFE - Bug (ID=75471)
Edited by Luke Letellier - May 17, 2016 16:26:58
- Luke Letellier
- 241 posts
SideFx support helped me figure out the issue: If the file paths for your files have a space between words, hbatch will not run and your background render won't do anything.
So if your file path is similar to #1, you need to remove the space between the words to look like #2:
1. /MyCompany/Client/Project Name/Houdini/renders/MySim_$F4.bgeo.sc
2. /MyCompany/Client/Project_Name/Houdini/renders/MySim_$F4.bgeo.sc
The same is true for the location of your HIP file itself; make sure the path doesn't contain any spaces between words.
SideFx is planning to fix this inconsistency, but it's probably a good practice for us to adapt our files paths in such a manner anywho.
Edited by Luke Letellier - May 19, 2016 09:58:00
- Ben Watts
- 32 posts
Luke Letellier
Thanks for that info Luke, appreciate it
Kind Regards,
Ben
Ben
