Hi everyone,
Im working on a project where I will need to build a lot of wires which will stretch and eventually snap, like pulling steel cables apart.
I am attempting to do this with the fracturing parameters in the wire object but it does not work. Does anybody have an example of being able to break a wire using the wire fracture?
Or is it easier for me to just use the pre-cut wire and animate a glue constraint?
Any help at all would be great.
Wire object fracture: how does it work
6666 5 1- rayt
- 12 posts
- derrick
- 332 posts
rayt
Hi everyone,I am attempting to do this with the fracturing parameters in the wire object but it does not work.
The Wire Solver's fracturing works by unsharing points, not by splitting primitives. Consider pre-fracturing the wire geometry and using the Fuse SOP to join the pieces before simulation.
- rayt
- 12 posts
- tamte
- 8833 posts
- rayt
- 12 posts
- omgponies
- 8 posts
