Wind profile
5583 5 4- phtj
- 224 posts
Hi all,
We are trying to create a wind tunnel simulation (using the smoke solver) around a building. For this, the wind speed needs to lower at the bottom and higher at the top of the building.
Here is an image that shows the wind speed profile:
http://www.wbdg.org/images/airbarriers_3.gif [wbdg.org]
In the ‘Smoke Object’ node, we can set a constant wind speed in “Wind Tunnel Direction”. Is there a way we can vary the wind speed with height?
Patrick
Patrick
Patrick
- PradeepBarua
- 443 posts
https://vimeo.com/44129053 [vimeo.com]
Check around 17:00 min where Scott explain how to create custom wind field.
- phtj
- 224 posts
Thanks Pradeep for the tip on the video. I created a test model - the file is attached.
It kind of works at the start - .e. the wind velocity at the start of the animation is slow at the bottom and fast at the top. But it does not stay that way - strange things start happening. Basically, the velocity of the wind at the top where there are no obstructions should stay more or less constant - which is not the case.
Any suggestions on how to fix this? I get the feeling the problem may be to do with the inflow and outflow of the wind at the boundary.
Patrick
- phtj
- 224 posts
- vigneshkaushik
- 20 posts
Does changing the border type from constant to repeat help? I have attached screenshot of both scenarios. In border type=repeat, the volume seems to wrap returning values from opposite side of the volume. I am not entirely sure if that is the same as a constant initial wind profile. Can someone clarify pls?
Cheers
ViSiKa
ViSiKa
- old_school
- 2540 posts
Here's my shot at it.
- velocity source using a user-placed box and ramp to define wind force in Y.
- Smoke container with velocity only. No smoke (not needed). Visualize vel field.
- building collider and ground plane collider
- volume closed boundaries open in +Z only
- Add vortex confinement to velocity.
Pretty cool.
Pretty cool.
