H14 ubuntu: exr map format issue environment light
   3340   2   0
houdini-14.0.291
Distro : ubuntu 14
Hi to all, i am trying to set an .exr map in the environment light node, in the light pan environment map section, i have put an .exr map,but when tryng to render with mantra the render gone black.
after searching the problem,i have found that mantra doesn't want to render environment map in exr format, while .Hdr format render through mantra without any issue.
So can you help me to resolve this issue,i know i can convert the files to .hdr but in the past version of houdini ( houdini 13),i have never facing this issue.
thanks in advance for help. :wink:
your best chance to get help (answers) is to join your hip file
mor Mave
thanks for your response, seem the problem was gone after installing kde desktop,know i can render without problem with .exr files
