While pyro instancing works fine for most of the situations, the tracking object feature doesn't work properly with track by object turned on in the Gas resize fluid dynamic node.
I dig into the Gas resize fluid dynamic dop node, but couldn't find a solution to make it work. What i want is that each cluster container will resize according to each track object of its cluster.
Hope someone can help.
pyro clustering with tracking object
4680 1 1- WhimmY
- 18 posts
- PradeepBarua
- 443 posts
Did you check Rob's file here:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=26547&highlight=clustering [sidefx.com]
and Dobril's here:
http://forums.odforce.net/topic/17266-smoke-trail-on-path/ [forums.odforce.net]
If you have any problem let me know I have my version too.
and Dobril's here:
