Sculpt node issue
   2288   2   1
Hello
Kindly help me with this issue :
the Sculpt node is not working properly with me .
on the operation for all drop down list , whenever i choose anything it gets me back again to deform points .
Regards
Hello ,
I found a work around for this problem which is to use the right click menu on the view port and choose what type of operation you want to use , it will work this way.
Regards
I also had this problem and it was fixed in the latest build.
I hope that helps.
https://vimeo.com/user2163076 [vimeo.com]
