Scene defaults
6523 6 3- Steadicam
- 33 posts
Is there a way to make changes to the default “untitled” scene that loads when you first open Houdini? It's not a huge deal but I do find myself doing a lot of repetitive tasks beyond normal preferences to accommodate HToA and a couple of other workflow idiosyncrasies. Obviously, I could create and manually load a common HIP but I thought I'd see how lazy I can get.
- Anonymous
- 678 posts
Look for 123.cmd. You will find there name of the file which is called by this script to setup the default scene.
EDIT1: Don't modify this one. Make new one in your
HOME\houdiniX.XX\scripts
The easiest way to create custom setup in 123.cmd file is to create example scene in Houdini and then save it to 123.cmd file with a help of
opscript
command.
EDIT2: You can also create python version of this file called
123.py
but I don't know is there possibility to save setup of your scene to it as easily as with opscript command.
opscript
command.
123.py
Edited by - June 10, 2015 16:28:20
- old_school
- 2540 posts
There are several ways to customize Houdini on load.
The most common is to use either a 123.cmd or 123.py file with hscrpt or python Houdini commands to configure Houdini to your liking on start-up. These are run every time you launch a new Houdini session
If you want to force load a setup every time you load a file either new or in session, you can create/edit a 456.cmd or 456.py file.
- kikou
- 25 posts
Steadicam
I'd be interested to know more about those tediously repetitive tasks for HtoA, maybe I can do something about it to ease the pain.
Frederic Servant / Solid Angle / London
www.solidangle.com
www.solidangle.com
- Enivob
- 2627 posts
I also do a lot of repetitive setup on the Mantra node every time. For instance, I want my tile size to be 48, not the default of 16. When I right-click there is a menu option to make the current value the new default. I tried that, but it does not seem to “stick”. When I open up Houdini again and create a new Mantra node the old value of 16 is still there.
It would be nice if Houdini could de-couple preferences from the UI kind of like the way Blender does it. If I setup a Display option Houdini warns me “Hey this really does not work, if you load a new scene you are going to get that scene's settings”. In Blender there is an option called “Load UI” which is on by default giving it a similar functionality to what Houdini does now. But you can uncheck the “Load UI” and not inherit some other users values for a UI but still load the file into your UI setup.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Anonymous
- 678 posts
Enivob
… When I right-click there is a menu option to make the current value the new default. I tried that, but it does not seem to “stick”. When I open up Houdini again and create a new Mantra node the old value of 16 is still there…
Have you tried to setup you node and then go to Gear menu and pick “Save As Permanent Defaults”?
- wyhinton
- 4 posts
