Trail a VDB Surface?
   2615   3   1
I am using a the trailsop to accumulate over time a piece of animated geo and converting it to vdb surface to attain its volume it has occupied in the shot.
Though I was wondering if there is a way to convert the poly object to vdb first, then accumulate the volume directly?
soho vfx
… not possible? :roll:
soho vfx
You could use a SOP Solver with a vdbcombine inside of it (set to add)
vdb_solver_example.hip (64.4 KB)
www.kmcnamara.com
That worked perfectly! Thank you sir. I owe you a beer. :wink:
soho vfx
