AutoDOP network
   2760   4   1
Hello, guys. I make a project with ball, that breaks a wall. I want to decrease time scale at certain frame, but nothing happens . Have anyone done this before?
Could you speak more clearly? Now definitely not clear what you want to do. It is best to attach a scene. I made a very simple example with using node Drag, but I'm not sure this is what you need.
ballanddrag.hip (275.7 KB)
Sorry for my english. I have a scene with breakable wall. And at 24 frame i want to slow physic and move camera around scene.
Venikman1
Ha. We did similar task. But we went the other way. To simulate this effect recorded in sequencing .bgeo. Then, with the aid of a node “Timeshift” did time warp (also timeblend, timewarp). but in this case you need to write a large number of frames per second (60, 120). The same can be done with a “chop” and example you can see in help: http://www.sidefx.com/docs/houdini14.0/nodes/chop/warp [sidefx.com]
Nice, i was looking for this kind of effect.
So it looks be easier to create the simualtion before and then create the slowotion than create the slowmotion directly in the simulation…. I was not sure, but it sounds logic, like that, you don't need to play around with a lot of parameters
Thx for the advice,
Want to learn more and more…
