Im having trouble reading tiff images rendered by houdini
on other software … like aftereffects or finalcut
Ive tried all the avialable format options.
Im making 16 bits per RGB pixel images.
Has anyone else noticed this …
is there a fix?
tiff image format ureadable outside of houdini
15023 16 0-
- WillA
- 98 posts
- edward
- 7967 posts
- JColdrick
- 4140 posts
Tiff is usually the best option when you start to get into more than 8 bits, and the target software doesn't support OEXR, but I must admit to wondering about this whole tiff compression issue. Back in the day, when the initial threats of lawsuits over the lzw compression were raised, the sky was falling and suppliers started pulling it from their export options. I do recall SESI keeping it(I thought), and there being a slight issue over “Adobe Deflate” compression. My understanding was that this was essentially lzw compression with Adobe doing the typical corporate thing and sticking that phrase into the magic portion of the file, but otherwise it was just plain ol' lzw. I have noticed for some time that a number of apps, Adobe as mentioned and some Mac apps won't read SESI's compressed tiffs. At least that's the whine I hear from the Mac camp.
Can anyone speak clearly on this issue? It's been pretty frustrating for us having to use uncompressed tiffs.
It is worth mentioning, however, that much of the time I've actually spoken to those mac users, I find out they're using apps that only support 8 bit. Clearing the chaff from that wheat has been a pain.
J.C.
J.C.
John Coldrick
- edward
- 7967 posts
AdobeDeflate is actually a gzip compression and is the same as “Deflate” except with a different compression type id. It's true though that Houdini avoided LZW compression due to patent issues.
I asked about the difference between AdobeDeflate and Deflate on the libtiff mailing list a while back. According to Chris Cox of Adobe (which I suspect is from the Photoshop side), this is “Because someone outside Adobe defined a flate compression value and ignored the value defined by Adobe as part of the TIFF standard.” He never replied to my comment that After Effects didn't seem to load AdobeDeflate files though. I would have though that After Effects would support AdobeDeflate by now though.
For some reason, libtiff, the library by which what most people use to read and write tiffs, only supported Deflate initially. Houdini up until version 5 or so wrote out tiffs using Deflate by default. At that point, some customers complained that they couldn't use the tiffs output by Houdini with some Adobe products and so we changed the default to AdobeDeflate. This of course then broke other apps which used old versions of libtiff.
The short of it is to set your tiff compression type to the one that you need if the default doesn't work for you. I believe iconvert can be used to to change the compression type on existing tiff files when given the right options.
- JColdrick
- 4140 posts
- deecue
- 412 posts
good info edward.. thanks..
willa:
AFAIK AE won't support 16 bit tif's.. In fact they claim only 24 and 32 bit files are supported along with some 16bpc quicktime codecs. seems really stupid considering you can work in 16bpc.. as a side note, i tested out by just creating a 16 bit tif and psd out of photoshop.. tif was a no go in different compression methods but the psd was.. go figure..
another option that you might want to consider is working with openexr and eLin…
http://redgiantsoftware.com/elin.html [redgiantsoftware.com]
willa:
Dave Quirus
- Simon
- 2199 posts
One really nice thing about using Houdini tifs with photoshop (at least 8bit ones) is that they have an “assiociated” Alpha channel, i think that's the expression. Anyway what it means is that photoshop reads the alpha channel correctly and converts it to it's own transparency type. If you don't do this and just load the alpha channel as a selection after opening a image and then delete the background it leaves black in the foreground portion that shouldn't be there. Not sure it After Effects does the same thing. But basically if you want transparency in an Adobe product probably best to start with tif.
- deecue
- 412 posts
- WillA
- 98 posts
We had trouble in windoz aftereffects but got it going by
gettting the free supertiff plugins at the site below
http://www.fnordware.com/ [fnordware.com]
there are dowloads for MAC as well
for your info
uncompr … 16bit per channel uncompressed
packbits … 16bit per channel compression=packbits
adeflate … 16 bit per channel compression=Adobe Deflate
sdeflate … 16 bit per channel compression=Standard Deflate
the compressions are all lossless but the deflates makes the smallest files
90% of the time.
in WINDOZ:
aftereffects 6.5
-adeflate
-packbits
quicktime 6.5.2 pro
-uncompr
photoshop CS 8.0
-uncompr
-sdeflate
-packbits
-adeflate
Pete M. at axyz(Toronto) made this nice summary for MAC software
Final Cut Pro v4.5
-uncompr
Photoshop CS
-uncompr
-sdeflate
-packbits
-adeflate
Preview v2.1.0
-packbits
-uncompr(but messed up)
Shake v3.5
-uncompr
-sdeflate
-packbits
-adeflate
After Effects v6.5
None. Parsing error This surprised me
(he had not yet acquired the supertiff plugin from
Illustrator v10.0.3
None. Error saying can't open files with that bit depth.
iPhoto v5.0.2
-uncompr
QuickTime 6.5.2
-uncompr
Haven't loaded QuickTime 7.0 yet. But apparently it is now 32 bit. Also Final Cut Pro 5.0 will be out in a couple of days and it is 32 bit as well.
Keynote v2.0.1
-packbits
Pages v1.0.1
-packbits
Summary
It seems that uncompr is the most compatible and second place would be packbits. Although Shake and Photoishop CS were fine with all four.
for your info
90% of the time.
in WINDOZ:
aftereffects 6.5
-adeflate
-packbits
quicktime 6.5.2 pro
-uncompr
photoshop CS 8.0
-uncompr
-sdeflate
-packbits
-adeflate
Final Cut Pro v4.5
-uncompr
Photoshop CS
-uncompr
-sdeflate
-packbits
-adeflate
Preview v2.1.0
-packbits
Shake v3.5
-uncompr
-sdeflate
-packbits
-adeflate
After Effects v6.5
Illustrator v10.0.3
iPhoto v5.0.2
-uncompr
QuickTime 6.5.2
-uncompr
Keynote v2.0.1
-packbits
Pages v1.0.1
-packbits
Summary
- deecue
- 412 posts
- edward
- 7967 posts
- deecue
- 412 posts
- edward
- 7967 posts
- rxs3817
- 3 posts
I don't know if this has been fixed in v8 but in Houdini 7 (up to and including 7.0.412 on WinXP), TIFF compression will revert to the Adobe Deflate scheme even if you've chosen Uncompressed and saved out the .hip file…
It took me a while to trace the bug - rather annoying all those unreadable file type messages in Nuke!
Roy Stelzer
Stelzer Productions
Switzerland
Roy Stelzer
Stelzer Productions
Switzerland
- edward
- 7967 posts
- gaucho
- 14 posts
rxs3817
Roy Stelzer
Stelzer Productions
Switzerland
Is there a way to resolve this issue ?
- malexander
- 5235 posts
You can edit the $HFS/config/FBoptions file, and change the compression type to whichever one you are using. The option is ‘compression’, the tags are ‘none’, ‘packbits’, ‘deflate’ and ‘lzw’ (see the FBoptions file for examples of how to do this).
It would certainly be nice if there was an easier way to set the default than editing this file. I'm not sure why the options aren't being saved in the hip files, as they are saved into a string parameter as option/value pairs. Perhaps they are, but aren't being restored correctly.
