TAB Submenu Path
   8184   9   4
There is any way to change the TAB Submenu Path via python??
I am sure there is, but I couldn't find it.
Thanks.
No one?? Please!!
Here is an excerpt from our bug database:
Yes, this can be done through HOM. The tools are defined as an XML file, which is stored in the “Tools.shelf” section of an HDA definition. The XML file format is documented here:
http://www.sidefx.com/docs/houdini14.0/shelf/config_file [sidefx.com]
For the Tab Submenu, you'd need to set the <toolSubmenu> tag.
You can add a new section by:
hda_definition = node.type().definition()
hda_definition.addSection(“Tools.shelf”, your_xml_string)
You could examine an existing section by:
tools_section = hda_definition.sections()
Also take a look at:
http://www.sidefx.com/docs/houdini14.0/hom/hou/HDADefinition [sidefx.com]
http://www.sidefx.com/docs/houdini14.0/hom/hou/HDASection [sidefx.com]
I did exactly that, but I was expecting something more clean, rather than add a section and append and xml file…
If this is the only solution, that's fine too.
Thank you very much rafal.
Is there a cleaner way now we are working with Houdini 16.5?
nope, were still dumping xml files to /tmp in 2018
jsmack
Thank you very much
Going to bump this thread again. Is there a cleaner way of doing this now?
Jim Watson
Senior Technical Artist
Bend Studio - Sony Interactive Entertainment (SIE)
Take a look at VHDA from Labs. It's still XML, but their code looks clean enough to me.
Michal Tas Maciejewski @ www.vfxtricks.com
tas3d
Jim Watson
