Constrain the points on a curve to a surface based on UV
   2777   2   2
So I have been trying to constrain a bunch of curves to some deforming geometry. I am creating some curves growing on an animated(deforming surface). I have generated the curves by drawing them by hand, using the findShortestPath. I have used raySOP, attribute Wrangle, bunch of other not functioning ways to glue it to the surface. I can get close, but my solutions all pop and wiggle.
My thought is to transfer the UV coordinate of the surface to the points on the curve via attrbitueTransfer and then use vopSop or vex to compare and find the matching UV coordinates on the curve and surface and move the points of the curve to the corresponding points on the surface.
I can get the UV data onto the curve from the surface on the rest frame, but I am struggling with building a compare and move that works.
I would attach my file but it is locked down by company policy.
Thoughts? Pointers?
Rob
here is one way to make curves stick on deforming geo
TimeShift/Ray/AttribInterpolate combo
ts_stick_on_deforming.hip (157.1 KB)
FX Supervisor
Method Studios, NY
Tamte,
That is a great solution. Testing it out right now.
Thanks so much.
