Procedural wirecapture?
   4058   11   2
Hi all,
I'm deforming a bunch of points along some wires, and I wanted this to be procedural, but I cannot find a way to automatically capture the points.
Is there a way?
I logged this as:
RFE: VEX based wire capture SOPs
The parameters could be driven by attributes. That would make a much better and faster workflow.
Thanks pusat,
At least I'm not missing something obvious. Shame ti can't be done currently…it's very non-procedural in it's current state.
As a side question: is it possible for me to see the RFE you logged? I can't find a way to view existing submission.
i don't know if it's for you helpful but you can get access to the parameter with python.
# Adjust the path to the wirecapture node
obj = hou.node('/obj/geo1/wirecapture1')
obj.setParms({“numprims”:2})
obj.setParms({“u0radius1”:0.2})
obj.setParms({“u1radius2”:0.8})
Anti-Distinctlyminty
Thanks pusat,
No there is no way to do that either. I and some other users asked SESI to make the RFE database public before. It would be beneficial.
A VEX solution to the WireCapture/WireDeform problem would be pretty amazing. It would pick up all these attributes like width, etc (that can be specified by name in the SOPs). I think the current workflow after you get the wire simulation is not very optimal.
Ah, shame I can't add my voice to your RFE.
Thanks for the Pyhon code mandrake0 - however, it would be grand to have the wire capture Houdini-ized as pusat mentioned.
Update:
Although you cannot seemingly do this using point attributes, I was after a very simple solution of applying the same value to all wires - which you can do by leaving the Primitive field blank in the Wire Capture node. Then it seems to apply the settings to all wire points.
new RFEs are checked against the DB and if you add something that is already there your RFE is made a duplicate and you are added to to existing RFE… setting aside human error
so there is no harm in adding the RFE…
Training Lead
www.sidefx.com
Any updates or workarounds available on this?
wlvl_yfx
Roll your own using prim intersection coordinates and building the matrix using the curve frame.
There's the Capture Attribute Unpack/Pack SOPs now so it opens it for manipulation with VEX.
here is an older experimental example using this capture pack sop. You can capture your geometry by a curve using xyzdist() for example and set weight / u attributes using ramps, other attributes or whatever and put them back into a vector (array). The pack sop is doing the rest for you.
wire_capture_pack_example.hipnc (87.0 KB)
