tube
   2617   3   2
Hai guys,
how to extrude a tube in houdini..
I'm not sure if I entirely understood your question because that's seem trivial :
-1- create a tube object
-2- on geometry node enable “Ends Caps”
-3- select top face and add an SOP “Poly Extrude” : tweak “Inset” param
-4- add another SOP “Poly Extrude” : tweak “Distance” param
Thanks for ur view, is there any tool similar to poke face in maya to join loop???
Your welcome.
Did you try Polycap ?
