Beep when render completes?
   3763   6   6
Anybody have success making the workstation beep when a render completes?
I tried the following script which works in Terminal/Python, but when I paste it in the post-render script (with type “Python”), I don't hear a beep.
import os; os.system(“echo ‘\a’”)
i can only get a popup window showing the sounds was executed….
if I use playwave pop.wav, I can get a sound to occur.
os.system(“playwave /usr/share/sounds/pop.wav”)
not sure if playwave is part of your linux install or not…but any shell based media player would work
Cool!
On Linux, I use paplay through the command line to play sounds when running a makefile.
You can hook it up in a python os.system() call as well or to a batch render.
# Play a sound on success or error through the command line
alias ok=“( paplay /usr/share/sounds/KDE-Sys-App-Positive.ogg & )”
alias err=“( paplay /home/guillaume/sounds/sadtrombone.ogg & )”
alias okerr=“&& ok || err”
What's neat is you can use a shell command return value to play a different sound if the command failed.
So I can run ( given my ok,err,okerr aliases are defined)
make okerr
and Il get a chime sound on success or the sad trombone on error.
I do hear the sad trombone a lot during a day.
Point of interest. Most install scripts I've come across obliterate those audio files directly out of the houdini/config/audio folder.
After 15 versions, I've developed a discernible Pavlovian response to those sounds. It's not pretty.
G
what about
print ‘\a’
Guillaume
(me smartassing) Maybe you should learn more then…
…or omit the sad trombone, someone will eventually notice sometime the make failed and tell you anyway…. :twisted:
If you can't script/program it, it's no good at all !
