is it possible to render without the watermark?
thx
render watermark
3684 1 0- Bernard
- 523 posts
- goldfarb
- 3464 posts
well there are two ways:
1) buy a copy of the software
2) render to the “pic” format
note that the pic format that Houdini uses will not be readable by anything outside of Houdini…SESI allows this format to be rendered without the watermark so you can use it in Halo for clean elements - then if/when you render to another format from there it will then be watermarked.
