Python script to change operator type
   2469   2   1
I would like to use python to run whatever functions are executed when you use the righ click menu > “Change Type…” on a Node. Because I have to do it on a number of nodes.
Does anyone have an idea how to change the operator type of a node?
That's what I have so far:
changeNodes =
objs = hou.root().recursiveGlob('*', hou.nodeTypeFilter.Obj)
for o in objs:
if o.type().name() == ‘nodeType_A’:
changeNodes.append(o)
for c in changeNodes:
#change nodeType to ‘nodeType_B’
#Keep name
#Keep Parameters
Any ideas? If there is a way to just get whatever code is run when I use the “Change Type…” that would already be of huge help!
Thanks a lot!
–Markus
You want hou.Node.changeNodeType()
Oh wow, that was easy! ops:
I wasn't thinking of looking in the API for the operations on Node. I only looked at NodeType…
Thanks so much!!!
