Mantra error code 139
   4928   2   0
I am trying to render a alembic generated from speedtree and I am getting this error, does anyone else having the same issue?
The problem only occurs if I try to render “Alembic delayed load primitives”.
Any tips?
https://vimeo.com/user2163076 [vimeo.com]
If I set the point attributes list of the alembic node only the “uv” attribute it works.
If anyone knows how to build the network already specifying the attributes that I want please share.
A 139 denotes a segmentation fault on Unix, which means the application tried to use memory it wasn't allowed to. It might not be the “Alembic delayed load primitives” but something in your env file as well that interferes with the loading.
I suggest making a new render only file that includes only what you need to render. And secondly strip out anything not needed for this render from your env file. You would be surprised what problems can be introduced with plugins and paths.
