Shader Connection
   1682   1   1
i am trying to create a shader with the help of tutorial, but version used in that is bit old mine is new, and iam finding it to bit difficult to find some of options used to connect nodes, pls help to solve issue…, create parameter node and vector and float connection is causing issue…
create parameter node.JPG (15.3 KB)
“Create Parameter” is now “Promote Parameter” in the MMB menu.
