Hi friends,
It's possible write a switch in wrangle? I mean write a code in VEX. Not switch sop or vop.
I can't found anything about switch in document.
If can, May I ask where I can find the information?
Well… maybe that will not be a big problem. But I would like use switch than if if if more.
switch in wrangle?
6694 2 0- igou
- 102 posts
- Enivob
- 2627 posts
A switch is just an IF/ELSE statement at the VEX level so sure, you can implement a switch and even route the condition to an external toggle channel you add to the interface.
http://www.sidefx.com/docs/houdini15.0/vex/lang [sidefx.com]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- igou
- 102 posts
