Is it possible to let i3d Volumetric Clouds cast shadows on a groundplane and how?
I did the i3d tutorial but they don't speak of casting shadows.
Many thanks,
bernard
i3d Clouds
12719 14 2- Bernard
- 523 posts
- Simon
- 2199 posts
- Bernard
- 523 posts
- craiglhoffman
- 252 posts
- Simon
- 2199 posts
- Siavash Tehrani
- 729 posts
Lisux has posted a couple new shaders that look like a big improvement over the standard i3d stuff. I haven't yet had a chance to try it out myself.
http://odforce.net/forum/index.php?showtopic=3004&hl= [odforce.net]
- addic3d
- 52 posts
- Bernard
- 523 posts
- AndrewVK
- 136 posts
- Siavash Tehrani
- 729 posts
- Simon
- 2199 posts
Bernard
I tried Filtered Shadows (textures) , but this doesn't work. Where can I set Raytraced Shadows?
Thx
Filtered Shadows are raytraced. I'm not sure what Filtered Shadows (textures) are. At the moment shadow maps (if that is what you mean) don't support transparency.
In shaders put down a VEX Shadow shader and select Filter Shadow from the drop down, then apply that to your light at object level via the Shading tab, SHOP Shadow parameter.
- Simon
- 2199 posts
- Simon
- 2199 posts
Actually I just tried this, and I think something might be broken. When you go to Shadow mask for the light and try to select the fog object it doesn't show up. I think maybe when bundles got introduced this may have been over looked. I'll find out for you.
- Bernard
- 523 posts
I read something about shadows on id3Clouds, and it seems that it is impossible with Atmosphere render:
http://odforce.net/forum/index.php?showtopic=846&hl=clouds [odforce.net]
Thx
Thx
- Simon
- 2199 posts
