hi
I can get a setList in python easily:
alist =
setList = list(set(alist))
can I do this in wrangle?
thank you very much!
can i do this in wrangle?
2129 3 0- luoqiulin
- 303 posts
- animatrix_
- 4616 posts
You can use the array function:
http://www.sidefx.com/docs/houdini15.0/vex/functions/array [sidefx.com]
- luoqiulin
- 303 posts
hi pusat
thank you for your reply, I'm sorry that it's not clearly about my question.
alist =
print alist
print setList
after the “set()” the same value in the list are removed. the question is can I do this “set()” like option in wrangle? I wander if I do this in wrangle, it can be much faster!
alist =
print alist
print setList
- animatrix_
- 4616 posts
There is no set data type in VEX but I think I submitted an RFE for this a few years ago. While not the same, in Max, there is a BitArray data type which is very handy for variety of problems.
There is also no remove duplicates method AFAIK.
