Hi everyone I'm getting ready to setup some destruction in Houdini for one of my finals and I need to write a script that will go into each geometry node from my alembics and cut / paste them all into one single geometry node. I'm new to python in Houdini and I'm just getting overwhelmed by creating simple lines of code like creating a single geometry node. I've written scripts in Python for Maya but Houdini it seems like I'm not understanding things or just trying to over complicate things but basically this is what I'm trying to do.
create empty geo node
select all alembic geometry nodes
store them into an array
then for the file inside the alembic
cut the file, paste into the empty geo node
and delete all the empty alembic geometry nodes.
Any tips or advice would be really appreciated. I know scripts are suppose to make life easier and right now my mind just gets overwhelmed from every error I'm getting. Hopefully what I'm trying to do makes sense if not I'll post an example file.
Python in Houdini
3536 4 1- Christian Olan
- 6 posts
- tony_a
- 86 posts
This should do the trick I think:
#Create empty geo node:
destination=hou.node(“/obj”).createNode(“geo”, node_name=“destination”)
#get all alembic archive nodes and put them in to a list:
alembic_archives=
for i in hou.node(“/obj”).children():
if i.type().name()==“alembicarchive”:
alembic_archives.append(i)
#get alembic geo nodes inside alembic archives
alembic_nodes=
for i in alembic_archives:
for x in i.allSubChildren():
if x.type().name()==“alembic”:
alembic_nodes.append(x)
#copy alembic nodes to destination geo node
hou.copyNodesTo(alembic_nodes,destination)
#remove leftover alembic archive nodes
i.destroy()
alembic_archives=
alembic_nodes=
i.destroy()
- goldfarb
- 3463 posts
- Christian Olan
- 6 posts
- Christian Olan
- 6 posts
arctor
instead of the copy method I'd use an object _merge node
I have a few scripts that do all this…I'll try to find them
Sweet thanks, I just learned you can import the alembic all as one hierarchy. I'll look into some blast expressions for reorganizing the different pieces for the different names.
Christian Olan-Geddes
