In H15, using a Point SOP to add a normal attribute to a mesh creates normals with a 0,0,0 vector.
It works fine in H14.
To make it work I had to add a Normal SOP before the Point SOP.
Could someone explain this?
Is this a bug or new functionality?
Cheers
Point SOP creates 0,0,0 Normals in H15
4091 6 1- noseman
- 345 posts
- noseman
- 345 posts
- noseman
- 345 posts
- jerry7
- 651 posts
- noseman
- 345 posts
- jerry7
- 651 posts
I guess it is by design. The doc indicate that SESI dose not suggest use Normal Parameter in Point sop, except modify existed N attribute.
http://www.sidefx.com/docs/houdini15.0/nodes/sop/point [sidefx.com]
Normal vector. If you just want to compute normals, please use the Normal node instead.
- noseman
- 345 posts
