Is there a way to import curve Cd to Maya vray? I've tried to promote Cd from point to vertex in Houdini, and connected the output with vrayVertex color node in maya, which works for importing geo. With curve, I can see the colorSet output in maya, but there is no submenu for colorSet/colorName. Any help will be greatly appreciated!
ycc
Import curve color attribute from Houdini to Maya
3551 2 2- opus2761
- 1 posts
- GlennimusPrime
- 85 posts
- Marco_M
- 5 posts
I found a way.
It doesn't show on the viewport like when using polygons, but the attribute still there.
The only thing you have to do is to connect a "UserDataColor" (will depend of your render engine) on Hypershape on Maya and type the custom attribute name exported from Houdini.
Note: The attribute must be a vertex attribute.
