Dynamics from scratch
   1735   1   1
Dear Houdini Users,
I'm trying to recreate a basic dynamics (soft body with a floor) setup in Houdini without luck. I made the grid for the floor intentionally.
I uploaded the scene file.
Thanks if you helping me. Have a nice day all of you.
dynamics_from_scratch.hipnc (243.3 KB)
In the dopnet, ‘grid1’ (the static object), you've left it in its default state to collide against a volume. Because your grid is an infinitely thin polygon plane, it can't be converted to a volume, so it can't collide.
Several ways to fix:
Turn off ‘use volume based collision detection’
OR
Convert your grid to something that can be made into a volume. A lazy way is to go back to your grid sop, and insert an ‘extrude volume’ between the grid sop and the attribcreate sop.
OR
use a ground plane dop instead.
