Hi.
I have written a network to simulate a boid. Now I want to take the result of the simulation to do statistical analysis. For this I need to take the position for each point and process it outside Houdini. Is possible take the information for each point and for each frame and then write to a file using the python api?
If yes may you point me to some basic example?
Thanks a lot!
Using Python to export data
3756 1 1- ja0335
- 11 posts
- mandrake0
- 645 posts
This is a simple obj exporter. you can see it's preety simple to export the data to a file.
for testing this use a python wrangler and pipe a mesh file with normals into it. change also the filepathname!
what you can do is to make a cvs exporter so you can use it in nearly any tool.
# Quick and Dirty OBJ Exporter
node = hou.pwd()
geo = node.geometry()
# Add code to modify contents of geo.
# Use drop down menu to select examples.
points =
for point in geo.points():
points.append(“v ” + str(point.position()) + “ ” + str(point.position()) + “ ” + str(point.position()) + “\n”)
pNormals =
pNormals.append(“vn ”)
for n in point.attribValue(“N”):
pNormals.append(str(n) + “ ”)
pNormals.append(“\n”)
faces =
for prims in geo.prims():
p =
p.append(“i”)
for vertices in prims.vertices():
p.append(str(vertices.point().number()+1)) #there is no face with a value of 0 => +1
p.append(“\n”)
faces.append(' ‘.join(p))
# Export OBJ Data
file_obj = ’C:\\dev\\houdini.obj'
f_out = open(file_obj, ‘w’)
f_out.write(“g\n”)
f_out.write(''.join(points))
f_out.write(“g\n”)
f_out.write(''.join(pNormals))
f_out.write(“g\n”)
f_out.write(''.join(faces))
f_out.close()
node = hou.pwd()
points =
pNormals =
faces =
p =
p.append(“i”)
p.append(“\n”)
# Export OBJ Data
f_out.write(“g\n”)
f_out.write(“g\n”)
f_out.write(“g\n”)
f_out.close()
