Texture transformation node?
3457 3 1- deadalvs
- 196 posts
- grayOlorin
- 1799 posts
If you wanted to do it before the shader, you can actually use a copnet to modify your texture (transform or anything else ), then feed it into your material texture input using the op: syntax
opobj/cop2net/somenode
Or this for relative
op:`opfullpath(“../cop2net/somenode”)`
However, you can also in the shader transform your s and t before feeding into the texture vop without modifying uvs
-G
- Siavash Tehrani
- 725 posts
- deadalvs
- 196 posts
