Dops expression problem
   3488   2   0
Hi everyone,
I am having problems of using dopsnumrecords() in sops, It will display probably in the field but it won't update the parameter.
e.g. I use the dopnumrecords(“/obj/dopnet1”, 3, “Impacts”, “Impacts”) to driven the Y translation of a grid. I can tell it's getting the correct value in each frame when I click on the parameter name, but the grid just won't move at all.
It seems that Dops expression will only update the SOP parameter at the frame when the exp was created and I remember I used the exactly same expression on the alpha version of DOPs and it was working fine… …any idea for this one?
thx
Hammer Chu
Could you post your hip file here so I can have a look at it? Or if you don't want your hip file available in public, please email it to support@sidefx.com and explain that you are sending it in response to this forum thread.
Thanks,
Mark
Is this a case of having to set the “Set Always” option on the parameter in question? Where it currently says “Use Default”, change it to “Set Always” and see what you get.
