(Help) Fixing Imported Curve point order
   2633   3   1
Hello Community,
I'm working with some curves from a cad software. Problem is when I load it in the curve, the point order is a mess. I feel there should be easy to fix but I guess the solution is eluding me.
-Sort won't work cus of complexity.
-Prim order is also a mess.
tube_curve.dxf (6.3 KB)
Fuse - Join - Fuse
works for me.
Hello.
Do you want to be point & primitive numbers exactly the same as your CAD program?
If yes, what's your order?
@Konstantin - Thanks this what I wanted. Knew had to be simple.
@Nima - No didn't need it to match. Just be able to have the carve node recognize the imported curve as a whole and not individual segments. Also have the sweep + skin node work correctly.
