hey guys, I have recently finished digital tutors “introduction to houdini 15” and was wondering where I should go from here and what my main focus should be.
cheers.
What to do
2784 5 1- Bilale
- 1 posts
- bonsak
- 459 posts
- goldfarb
- 3459 posts
- BabaJ
- 2110 posts
I think that depends on how good your “memory” is. And I mean your brains memory not computers.
When I first started Houdini I went through as much of the tutorials that were available.
But at some point you become saturated and can't hold on to remembering too much.
I have found the best approach is to think about what you would like to create ( and be ambitious even if your only a beginner )
This will help narrow down which tutorials and areas of Houdini to focus on at the same time giving you experience in applying what your learning instead of simply following a tutorial.
- blackpixel
- 182 posts
Aggree with Babaj. Tutorials are great, but a personal project keeps you focused Set yourself a goal, but keep it simple (!) If you try to overachieve and fail you will just be frustrated ( Believe me, we've all been there ). If you hit a roadblock, just ask in the forum and I'm sure a lot of people will help you out
Also from time to time open the help browser and type a random letter, then select a random page and read it.
This might sound ridiculous, but you'll be surprised how often you find something new about a node or a function you use all the time.
- grayOlorin
- 1799 posts
I would have to +1 this. Tutorials are great to learn “vocabulary” (and you can still watch them), but putting Houdini to a practical use is easily the BEST way to learn it. In my first days learning Houdini, I would force myself to solve problems at work in Houdini, while still watching (just watching, not “following and doing”) tutorials to learn vocabulary and helped a lot
also keep in mind that there are MANY ways to solve problems in Houdini, and the first solution that you come up for something will seem obsolete after a year of using it. Enjoy! it's been a fun ride since I got into it!
-G
