NULL at the end of a network
7871 10 2- _Christopher_
- 767 posts
- Sean Rowe
- 39 posts
- _Christopher_
- 767 posts
- grayOlorin
- 1799 posts
do note however, that from houdini 14 on, you can use explicit output SOP nodes, which are MUCH better than nulls for this. The reason why is because, what is set as the visible node in a sop network, may not be what you want to output (i.e. if you are debugging and forget to set your visible flag to the output node, you could explode…)
I actually also use nulls in my network inputs to be able to visualize those better too (i.e. I do not like the first node in a sob subnetwork to immediately modify the input, I want to be able to see what the input is from inside). I name these IN_something and color them yellow
Last, nulls are also useful as “hook” nodes. Basically if you have a part of your network that is interesting for some reason (i.e. you reference its bounding box, or try to get an attribute from it), it is a good habit to branch off a null node so that you know that in the middle of your network, there is some interesting data you reference. I color these green, and name them null_someUsefulName
hope this helps!
hope this helps!
-G
- _Christopher_
- 767 posts
Gary I don't understand what you mean ?
I wouldn't mind if you could explain your method ?
【T】【C】【S】
- grayOlorin
- 1799 posts
Before output SOPs, if you were going over nodes on a subnet (say for debugging an error) then change something, exit the network but forget to set your display flag on the last node of that subnet, you would cook subsequent nodes outside of that subnet with the node you left visible as the actual output node, which may cause unexpected results (for example, if you leave a really hi res version of your mesh, then exit, and have a ton of geometry operations after, you will be cooknig for a while). Output nodes make it so that this cannot happen. if you set an output node inside of a subnet, it does not matter which node is the display node in that subnet, as the output will be driven by the output node (plus it also allows for multiple outputs)
if you create a subnet in any sop network, notice how inside, the first items on the subnet are small boxes symbolizing the inputs of your subnet node. If you add, say, a clip SOP right after your first input box, there is no way for you to see what that plug is passing through into your subnet without either disabling your clip node, or exiting the subnet. Adding that null node in between the clip node and the small input box is a way to have a representation of your input geometry accessible in your subnet as is
-G
- _Christopher_
- 767 posts
If I understand you correctly Gary, you are saying if I don't set the last node in a subnet as a display flag I would cook the nodes outside of the subnet, unless I use a output SOP within the subnet then and only then would the network stops calculating once it reaches the output SOP ?
I didn't know you could do representation within a subnet, I still don't understand how does adding a null between the little subnet boxes and a clip node add representation ? As well you mention without the null within the subnet, there is no way for one to see what plug is passing though your subnet, how can I see this in practice ?
【T】【C】【S】
- grayOlorin
- 1799 posts
Not quite. What I am saying is that the output SOP is the explicit output node of a subnet, and not having one, houdini will default to whichever node has the blue flag on as the actual output (which could have unintended results). In short, you should always use an output SOP
By representation, I mean the ability to see the mesh of a particular subnet input from the inside, before it has been modified by a mesh inside the subnet. Try building a scene similar to the one I explained:
in a new houdini scene, add a geometry OBJ node
dive inside (you should have the default cube)
add a subnetwork SOP, and wire the output of the default file sop to the first input of the subnet
dive inside the subnet
add a clip sop and wire the first input box to the first input of the clip sop
notice how, although you can see your modified cube, you cannot see the unmodified version without exiting the subnet
now add a null node in between the input box and the clip
notice how now you can visualize the first input mesh of the subnet without having to exit the subnet
-G
- _Christopher_
- 767 posts
Oh This is why nulls are used.
Use an output SOP whether within a subnet node or not, correct ?
【T】【C】【S】
- grayOlorin
- 1799 posts
- _Christopher_
- 767 posts
