Particle fluid surface issue
   3288   2   0
Hi I have a weird issue with Particle fluid surface
anyone had this before ??
[postimg.org]
[postimg.org]
Houdini 15.5.523
Morteza
I've seen it when using a particle emitter, it was related to the shape of the emitter, not sure if this is the case here tho.
I just banged my head against this, and found out that the Fuid Compress -node was the one to blaim. I disabled the Volume bandwidth limiter, and the weird boxes disappeared.
Screenshot attached.
