I have a little problem with the hdk. I have a custom node that create parameters dinamically (inside a button callback function). My parameters are correctly created on the node, but I would like to move those new spare parameters inside an existing folder. It's the same process you can do using the drag&drop inside the Edit Parameters Interface. I would like to do in in c++, but if there si no solution I could you also python. Ther is any solution?
Alan
[HDK] Create a new spare parameters inside an existing folder
1842 1 0- iaiotom
- 7 posts
- quick7silver
- 1 posts
