G'day All!
Just wondering if anyone has tried Houdini on MacOS Sierra? It's out pretty soon and I'm a bit keen to try it out
(It'd be awesome if SideFx added support for full screen one of these days too…)
Pete.
MacOS Sierra
11727 17 5- peteski
- 518 posts
- ed_co
- 14 posts
- chrism
- 2551 posts
- kevinthebright
- 214 posts
- Ulrich Pinkall
- 2 posts
After upgrading to MacOs Sierra my Houdini stopped working. The old license administrator for Houdini 15.0 does not even start (it exits silently from the dock after a minute or so, before even showing a window), so I installed 15.5.609. Now the licence administrator starts (after a long delay) but it asks me to upgrade the license server (see attached screenshot). The server that is running is
/Library/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/sbin/sesinetd
while “Current” points to the 15.5.609 directory. But still the same behavior…
Ulrich
Ulrich
- kevinthebright
- 214 posts
- peteski
- 518 posts
- silvina
- 181 posts
- Ulrich Pinkall
- 2 posts
- webbingbcn
- 1 posts
Recently installed in my Mac and working perfectly (v 15.5.594). If doesn't, try to upgrade.
Webbing Barcelona - Agencia especializada en diseño web en Barcelona [webbingbcn.es].
- shmo
- 9 posts
silvina
For OS Sierra licensing problems, as a last resort, you could add a mapping to your /etc/hosts file. You just need to add this line to the file:
127.0.0.1 name-of-my-machine.local
PROBLEM:
hmm.. this did not work for me. im getting ‘cannot connect to lisence server’ error
EDIT / FIX:
In the lisence server clicking the ‘Local host’ button fixed this problem.
If anyone know why this worked I would love to know.
Thanks,
J
Edited by shmo - Oct. 29, 2016 14:42:24
- steves
- 1 posts
Hey All
I've had a massive problem since upgrading my MacBook Pro to macOS Sierra. Firstly the license server failed to work when I ran Houdini 14.0 with the error "Cannot connect to the license server on .local". As Im only trying to run the Apprentice version, I figured it was time to just update to the latest Houdini 15.5.632. That installed fine however it is so slow its unusable. It takes a full minute to simply drop down a geometry object in a new scene, then another minute to go inside the new object, another minute to select the file node in there, another minute to put down a circle sop, and another minute to change the scale, etc etc etc.
These steps were instantaneous pre-Sierra so Im wondering if anyone else has similar problems or a way to fix it as there is no point trying to use Houdini when it is this slow. I haven't seen any negative effects with other software since the update, and even though its an older machine, I don't want to have to upgrade just to run an apprentice version of Houdini.
I've put the specs of my machine below but if anyone has any suggestions on how to get it back running the way it was before the os update that would be greatly appreciated!!!
Steve
Machine Specs
macOS Sierra (version 10.12.1)
MacBook Pro (13-inch, Late 2011) (I know its old but everything was running fine previously)
Processor: 2.4 GHz Intel Core i5
Memory: 8 GB 1333 MHz DDR3
Startup Disk: Macintosh HD
Graphics: Intel HD Graphics 3000 512 MB
Steve
Machine Specs
- anon_user_37409885
- 4189 posts
- peteski
- 518 posts
- rizalalthur
- 1 posts
- cgbeige
- 99 posts
- 7pc
- 22 posts
- Igor Backstrom
- 26 posts
steves
Hey All
Steve
Machine Specs
I've got same configuration and same problem. It just don't work.
