I'm trying to use the Polyextrude Local Frames attributes (X Direction, Z Direction and Center), but it doesn't seems to work. In the manual says it's a vector attribute of type primitive if you are extruding faces.
The Local Attributes it's working, Distance Scale and so on.
I'm not sure if I'm doing something wrong or it just a bug.
Poly Extrude 2.0 Attributes Problem
2790 2 0- FabianoBerlim
- 36 posts
- bonsak
- 459 posts
Hi
You need to enable “Transform Extruded Front” on the “Extrusion” tab and also set “Translate” (or any other transform) to some value other than 0. The “Local Frames” attributes you pass in modifies these extrusion transform values. So if they are zero, nothing happens
-b
-b
Edited by bonsak - Oct. 10, 2016 18:17:05
- FabianoBerlim
- 36 posts
