DOP POP curl noise question
   2108   1   0
Is there a way to freeze the transforms of a curl noise in a DOP popvop? I am running a point sim and my source emitter object is animated and rotated in world space. When the points emit, the curl noise added to the point position slides. I'm really not sure what to do in the popvop to freeze the curl noise.
Ive tried using a popforce, however the curl noise does not seem to create the same shapes that the popvop does.
Thanks in advance.
Why don't you try to animate your curl noise?
Edited by Nima - Oct. 21, 2016 16:16:38
